Displays IPv6 statistics handled by the CPU for the switch for a particular VLAN.
name | Specifies a VLAN name. |
tunnel_name | Specifies a tunnel name. |
N/A.
This command only shows statistics of the CPU-handled packets. Not all packets are handled by the CPU. For example, packets forwarded in hardware do not increment the statistics counters.
The following example displays IPv6 statistics for the VLAN accounting:
show ipstats ipv6 vlan accounting
The VR option was removed in ExtremeXOS 30.1.
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
